- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 dsl modem and router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000 dsl modem and router
> D7000 [...]
D7000[v1] or D7000v2? Look at the product label. Firmware version?
> [...] how can I correct the issue[?]
Replace this modem+router with some device (or set of devices) which
works properly? I wouldn't expect Netgear to produce one.
https://community.netgear.com/t5/x/x/m-p/1782476
Please report back here if/when you find a good replacement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bowen1911 wrote:
My router modem seems to need reset after about 30 days of “ non use “
Do the logs on the modem/router give any clues as to what causes this?
What symptoms prompt this need for a reset?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
Have you looked into remote management to check on things while you are away?
@bowen1911 wrote:
....my cameras, etc stop working because of this how can I correct the issue.
If your cameras are always on and creating Internet traffic, then "non use" does not seem to apply.
Does your ISP force some sort of scheduled reset? That has come up here in the past.
