Orbi WiFi 7 RBE973
Reply
D7000 firmware 1.0.1.70 GPL Source Code MIssing
negan07
Tutor
The D7000 last firmware version 1.0.1.70 GPL source code has been wrongly linked into the NETGEAR-Open-Source-Code-for-Programmers-GPL and can't be downloaded.
This is the link involved:
https://www.downloads.netgear.com/files/GPL/R065-A-2018-0247_D7000v1 GPL.tgz
The blank space between "D7000v1" and "GPL" makes the link unreachable even if file is located also with %20 blank char code:
please fix it otherwise no way to obtain the source package.
Regards
Model: D7000v1|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
w3wilkes
Prodigy
Re: D7000 firmware 1.0.1.70 GPL Source Code MIssing
If you are sure that the Open source code Netgear is using is not being made available you should follow these instructions to report this violation of the license terms.
https://www.gnu.org/licenses/gpl-violation.en.html
Message 2 of 3
Nodism1125
NETGEAR Expert
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1267 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
