Orbi WiFi 7 RBE973
Reply
D7000 losing ISP credentials after restarting
singleorign
Hi, I am finding my Nighthawk D7000 ADSL modem does not reconnect to the Internet after a reboot and I need to re-enter the ISP credentials.  The firmware version is V1.0.1.50_1.0.1.
Thank you for your assistance.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: D7000 losing ISP credentials after restarting
   No such problem here with the same model and firmware.
   Anything else changing?  Connection Mode = Always On?
   If the settings change spontaneously, then I'd probably resort to the
usual panacea, a full ("factory") reset, and then reconfiguration.  You
can try saving and restoring the settings, but if they're corrupt, then
a manual reconfiguration might work better.  Lasr resort: re-install the
firmware.
   Bad hardware (NVRAM) is also a possibility, I suppose.
Message 2 of 4
All Replies
antinode
Guru
firmware.
Message 2 of 4
TheFamilyDog
Initiate
Same issue and FW version here. Just spent 30mins troubleshooting - then had to reenter credentials.
At the same time it also switches off the wireless radios so I have to dig out a laptop with an ethernet port to reenable them aaargh.
Message 3 of 4
singleorign
Great response!  Ended up needing to downgrade to 1.0.1.48.  Will keep that on for a little while for further testing and then later update to see if the credentials hold.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1073 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
