- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 with V1.0.1.70 problems post-reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000 with V1.0.1.70 problems post-reboot
What are you trying to sort out here?
Is this the key bit?
@bl1085 wrote:
Hello I have had a D7000 for approaching 2 years. Generally the basic DSL and network routing functions work very well. I also have an EX7000 and an EX7300 extender. I have a timer setup to reboot this router each morning so I get a different IP address each day - a tip from a network security professional.
Apart from wondering what the "security professional" is on about, the restart procedure can cause issues.
With several devices on a network, the order in which they start can be important. You don't want the extenders up and running before the modem/router.
I know this from bitter experience. When I had a modem/router in modem-only mode in front of a router, the modem took so long to restart that the router beat it to it and failed to connect to the internet.
As I said, I don't really understand what your issue is. (Too many things going on in one solid slab of text.) This is just one observation based on bitter experience.
There is support for the various D7000 options, including manuals, somewhere at the end of these links:
>>> D7000 | Product | Support | NETGEAR <<<
>>> D7000v2 | Product | Support | NETGEAR <<<
- Mark as New
- Bookmark
- Subscribe
- Permalink
I apologize for the difficult to read formatting. It looked nicely formatted into paragraphs on my screen before I hit submit, but then became a solid stream hard to read. I put a note to the moderator asking to delete it so I can repost it more legibly.
thx for your other comments - I will consider them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know those particular Extenders but have used other types in the past and it seems they were problematic, so at a minimum you should stop rebooting every day and see if that helps any.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bl1085 wrote:
After considering different options, I have decided to upgrade to the ORBI system and stop using the discrete range extenders. thanks to all who responded!
Orbi is certainly a good way of flooding an area with wifi, but first check that it provides all the features that you want. Things like USB and ReadyShare, for example.
And if you plan to use the D7000 as a modem, you will have to put it into modem-only mode or use the Orbi in AP mode. And that has its own implications.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
I also ran into an unexpected snag when I ran a modem/router (D6400) in modem-only mode. After a power cut, the modem was too slow to get its connection, leaving the router stranded and no internet all round. Not good if it happens when you are away. In the end I replaced the D6400 with a DM200, an inexpensive modem only box.
- Mark as New
- Bookmark
- Subscribe
- Permalink
