- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
D7000
I have a netgear D7000
I want to program it on the telecom companie but it does not give me options in the change country box to chose one of the available companies.
Please give me the solution .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000
You don't say how you are doing this. The browser graphical user interface (GUI) is the best way in.
You can also set up the modem/router manually.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
You will need to know what the settings are for your Internet service provider. What is this ISP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000
D7000[v1] or D7000v2? Look at the product label. Firmware version?
> [...] it does not give me options in the change country box to chose
> one of the available companies. [...]
Are you saying that you can't select a country or an ISP, or are you
saying that you can't select the _right_ country or ISP?
If you can set all the other parameters on that page properly, then I
doubt that the country or ISP settings will matter. ("properly" depends
on your ISP. You'd need to ask them what these values should be.)
> [...] What is this ISP?
A fair question.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000
please look at the photo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000
> Select Country [ USA ]
Ok. Netgear apparently disables choice of region on its USA models.
See also BASIC > Wireless : Region Selection (which I hope is the same
thing).
I know nothing, but you might look for "burnsku" in this old thread:
https://community.netgear.com/t5/x/x/m-p/1760057
Regarding enabling Telnet access, I use the program which I modified:
http://antinode.info/nte/
