- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000v2 - being offered differing firmware updates, & how to return to previous firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Present/original firmware installed is 1.0.0.41.
If I check via the Genie browser interface or Genie Windows program, it's offering me 1.0.0.51...
But if I check manually on the website, the latest is apparently 1.0.0.53: https://www.netgear.com/support/product/d7000v2?#download
Which one should I download & install please?
I'm in the UK if it makes any difference.
Secondly, if I find the latest not suitable for any reason, how do I go back to the previous (or install another) firmware? Manually download & install it from the downloads section? Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@GaT7 wrote:
Thanks for replying, but still wondering which to install, & would you happen to know if it's possible & easy-enough to return to an older firmware?
Yes. You can use whatever firmware you like.
They are all on the support pages for your device. The release notes tells you what to do.
>>>> D7000v2 | Product | Support | NETGEAR <<<<
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000v2 - being offered differing firmware updates, & how to return to previous firmware?
> [...] it's offering me 1.0.0.51... [...]
> [...] manually on the website, [...] 1.0.0.53: [...]
Netgear's firmware distribution procedures seem unlikely to win any
awards for organization. Search these forums (or the Web) for more
instances of similar questions.
Your choice? Do you want the latest one, or the one before that?
> [...] how do I go back to the previous (or install another) firmware?
Exactly. The Release Notes file should include instructions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@GaT7 wrote:
If I check via the Genie browser interface or Genie Windows program, it's offering me 1.0.0.51...But if I check manually on the website, the latest is apparently 1.0.0.53:
This is a "feature" of Netgear's process of rolling out new firmware. The automated updates sit on a different server from the library of available updates on the support pages. New firmware usually lands in the library before it hits the update servers, but it can go the other way round.
Sometimes new firmware will show up as a "hotfix" before it reaches the update server and before it lands in Firmware and Software Downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@antinode
Thanks for replying, so the latest firmware is not recommended then?
- Mark as New
- Bookmark
- Subscribe
- Permalink
