Reply
D7000v2 connectivity issue
We've been using my D7000v2 Nighthawk Modem Router for about 18 months.  We've been very happy with it, having only had to reboot it a couple of times.  We're not heavy internet users and it's coped fine with a couple of PCs, various mobiles, printer etc.
However, since Wednesday (23rd September) it keeps dropping all connectivity.  2.4G and 5G Networks drop as does the ethernet connection.  We haven't changed anything to have caused this.  All the LEDs are still lit on the router and it says there's internet, but clearly there isn't.  It's almost as if the router has frozen.
Firmware is the latest (1.0.62) and all devices (Win10, iPhone, Roku, Android) have the same issue.  There's no network being broadcast.  Rebooting solves the problem, but sometimes for only 30 mins.  I tried a factory reset on Friday, which solved the problem for 36 hours.
Any advice welcome.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 31
Re: D7000v2 connectivity issue
Any changes at your ISP end?
Start there first.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 31
mhaselup
Guide
I have a D7000v2 and I think my problem is very similar to yours https://community.netgear.com/t5/DSL-Modems-Routers/D7000v2-requires-reboot-at-least-every-7-days/m-...
I think it's likely a firmware issue, I'm thinking about looking at earlier versions but it's going to be a slow task going back and testing one version at a time until it works.
Message 3 of 31
Thanks.  I've reverted to Firmware V1.0.0.56_1.0.1, which I think I installed a few days before the problem started.  I've also spoke to my ISP and nothing's changed on their side.  I will see what happens over the next few days having reverted.
Message 4 of 31
An update, a few weeks later.
I've now performed a factory reset and entered ISP settings from scratch, without using a backup.  Originally, this was only at V1.0.0.56_1.0.1 and Genie told me I had the latest firmware.  However, checking online indicated that 1.0.64 was released at the end of September.  After a freeze with 1.0.0.56 I've upgraded to 1.0.0.64, which resulted in the longest run of not freezing for over a month.  However, it crashed this morning, after 5 days.
Situation is better, but still a be flaky.
Message 5 of 31
mhaselup
Guide
I've just upgraded to the V1.0.0.64_1.0.1 firmware (from 62 firmware). The longest run I had with the 62 firmware was 11 days before the router went down.
It will be interesting to see if the new firmware makes it past 11 days...
Message 6 of 31
My record so far, on 64 is 6 days.  It's an improvement, but still pretty annoying.
Message 7 of 31
mhaselup
Guide
Second day of .64 firmware
Decided to have a prod around in the logfiles on the router (/var/log/message)
This can't be healthy, writing 2 errors every 30s to the logs. Perhaps this is symptomatic of an issue that is leading to the exhaustion of the routers internal resources (every 10 days or so in my case)
/ramdisk/var/log # tail -f messages
Oct 24 19:06:36 D7000v2 syslog: do_session_mgmt returned fail for LAN
Oct 24 19:06:36 D7000v2 syslog: do_session_mgmt returned fail for WAN
Oct 24 19:07:06 D7000v2 syslog: do_session_mgmt returned fail for LAN
Oct 24 19:07:06 D7000v2 syslog: do_session_mgmt returned fail for WAN
Oct 24 19:07:36 D7000v2 syslog: do_session_mgmt returned fail for LAN
Oct 24 19:07:36 D7000v2 syslog: do_session_mgmt returned fail for WAN
Oct 24 19:08:06 D7000v2 syslog: do_session_mgmt returned fail for LAN
Oct 24 19:08:06 D7000v2 syslog: do_session_mgmt returned fail for WAN
Oct 24 19:08:36 D7000v2 syslog: do_session_mgmt returned fail for LAN
Oct 24 19:08:36 D7000v2 syslog: do_session_mgmt returned fail for WAN
Oct 24 19:09:06 D7000v2 syslog: do_session_mgmt returned fail for LAN
Oct 24 19:09:06 D7000v2 syslog: do_session_mgmt returned fail for WAN
Oct 24 19:09:36 D7000v2 syslog: do_session_mgmt returned fail for LAN
Oct 24 19:09:36 D7000v2 syslog: do_session_mgmt returned fail for WAN
Oct 24 19:10:06 D7000v2 syslog: do_session_mgmt returned fail for LAN
Oct 24 19:10:06 D7000v2 syslog: do_session_mgmt returned fail for WAN
Oct 24 19:10:36 D7000v2 syslog: do_session_mgmt returned fail for LAN
Oct 24 19:10:36 D7000v2 syslog: do_session_mgmt returned fail for WAN
Message 8 of 31
Thanks for the tip.  I had a look in my router's log file and there's nothing untoward there, just devices connecting.
Message 9 of 31
mhaselup
Guide
Six days and 4 hours uptime so far with V1.0.0.64_1.0.1
Message 10 of 31
mhaselup
Guide
Best run on .64 so far is 7 days and 7 hours. I wonder if their commercial products in datacenters are this unreliable?
Message 11 of 31
Annoyingly, it's got much worse over the past week.  We have to reboot almost every day after freezers.
Am going to try and engage with Netgear on the issue.
Message 12 of 31
fava
Tell me if u fix it I have the same device d7000v2 and it keep freezing every day I don't know how to fix and I'm teacher teaching by zoom its hard 4 me to keep disconnecting
Message 13 of 31
The guy I spoke to was very helpful, but says it's a software, not hardware issue, so not covered by warranty.  Annoyingly, it's cheaper to buy a new router than pay for tech support cover.
Also spoke to my ISP and there's no issue on their side.  I've tried reinstalling the firmware, so we'll see what happens.!
Message 14 of 31
mhaselup
Guide
I'm still running V1.0.0.64_1.0.1 firmware on the D7000v2. The modem logs are continuously generating sporadic error message but it's still up after nearly 10 days. This is the longest run by a large margin so far.
I am convinced the probem is in the modem firmware (hence the error messages).
The most recent fix I have employed to get the improved up-time is to disable DHCP (this clearly is not going to be a practical solution for everyone). If you are able to set fixed IP addresses for your router clients I would give this a go. I am using an Rpi running Pi-hole as a DHCP server to release to router from DHCP support.
If you try this out let me know if it makes a difference and what your best uptime is.
Message 15 of 31
mhaselup
Guide
Still up after nearly 11 days since I disabled DHCP at the last reboot. Sporadically spewing out error messages into the logfiles but remarkably still functioning given the error status is 'Critical'. Latest series of error messages is:
2020-11-30
17:52:25
Critical
D7000v2
user
mountd
failed while trying to read packet from kernel
2020-11-30
17:50:59
Critical
D7000v2
user
mountd
2020-11-30
17:48:52
Critical
D7000v2
user
mountd
2020-11-30
17:47:40
Critical
D7000v2
user
mountd
2020-11-30
17:47:12
Critical
D7000v2
user
mountd
2020-11-30
17:44:51
Critical
D7000v2
user
mountd
2020-11-30
17:43:42
Critical
D7000v2
user
mountd
2020-11-30
17:40:34
Critical
D7000v2
user
mountd
2020-11-30
16:38:43
Critical
D7000v2
user
mountd
Message 16 of 31
I've been keeping track of crashes more closely and have only managed a 7 day streak so far.  It usually throws a wobbly after 5 or 6 six days.  If you catch it in time, it's possible to reboot remotely rather than having to power on and off.  I'm convinced it's something to do with the wifi, as it never crashes at night-time when there's no traffic from our devices.
I've just updated the Firmware to V1.0.0.66_1.0.2 so let' see if that fixes the problem.
Message 17 of 31
w3wilkes
Prodigy
Wondering where you got this version? The version on the download page is V1.0.0.64_1.0.1.
D7000v2 / DGND3700v1
Message 18 of 31
I logged on to check my router settings in Chrome and there was an alert at the top of the page to update firmware and this was the version available.  I noted that the V1.0.0.64_1.0.1 was the only one on their website.
Model: R8900|Nighthawk X10 AD7000 Smart WiFi Router
Message 19 of 31
w3wilkes
Prodigy
Thanks. I logged in to the router and had it check for updates and the 66.1.0.2 was there. Normally Netgear does thing the other way round where the firmware is on the website but doesn't show in the router update function.
Message 20 of 31
mhaselup
Guide
Just updated to V1.0.0.66_1.0.2 will update with how long it stays up in due course. DHCP still disabled per my earlier post.
Message 21 of 31
ColMad
Now updated on support site
Message 22 of 31
mhaselup
Guide
V1.0.0.66_1.0.2 is up after "8 days 23:27:58". Continuing to spew out errors in the system log but still going at this point :-)
Message 23 of 31
I thought 66 had solved the problem, but no.  Crashed in the evening on Christmas Day, after 7 days up.  Crashing once a week is manageable!
Message 24 of 31
mhaselup
Guide
Firmware 66 finally died after a creditable 12 days, best run for a while. I think this is about as good as it's going to get. Time for a reboot.
Interestingly the router is still functioning as a router, that's how I'm managing to type this. This is the stage where all the attached devices start to fail to connect one by one before the complete meltdown. At this stage I cannot login to the router console page and can't connect wirelessly with a couple of other computers on this network and the error messages below are showing up in the log (for the last couple of hours).
2021-01-02
22:52:22
Critical
D7000v2
user
mountd
2021-01-02
22:47:07
Critical
D7000v2
user
mountd
2021-01-02
22:45:11
Critical
D7000v2
user
mountd
2021-01-02
22:44:13
Critical
D7000v2
user
mountd
2021-01-02
22:42:27
Critical
D7000v2
user
mountd
2021-01-02
22:42:05
Critical
D7000v2
user
mountd
2021-01-02
22:34:50
Critical
D7000v2
user
mountd
2021-01-02
22:32:50
Critical
D7000v2
user
mountd
2021-01-02
21:45:01
Critical
D7000v2
user
mountd
2021-01-02
21:36:05
Critical
D7000v2
user
mountd
2021-01-02
21:29:58
Critical
D7000v2
user
mountd
2021-01-02
21:11:17
Critical
D7000v2
user
mountd
2021-01-02
20:46:18
Critical
D7000v2
user
mountd
Message 25 of 31
Top Contributors
Discussion stats
  • 30 replies
  • 1374 views
  • 3 kudos
  • 6 in conversation
Announcements
