Orbi WiFi 7 RBE973
Reply
D7000v2 dropping internet and wifi freezing
coco99
Follower
D7000v2 running firmware V1.0.0.62_1.0.1
A few weeks after installing new firmware at Netgear suggestion (security update), this otherwise reliable modem/router has begun randomly dropping internet connection - no ability to access internet or routerlogin. Only solution is to power cycle.
Oddly, when it drops internet, intenet and twisted pair lights stay solid white, as do wifi radio lights (no traffic). I suspect this means that the modem part is still connected, but the router part (and wifi) thinks it is not. Have confimed with ISP that when I have no connection, ISP can see I am "connected".
Have searched boards and public info, and found no solutions, other than downgrading firmware.
Any ideas gratefully considered before I switch brands.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
antinode
Guru
Re: D7000v2 dropping internet and wifi freezing
> [...] other than downgrading firmware.
   Installing older firmware might reveal whether the problem lies with
the firmware, and not with some unrelated hardware problem.
      https://community.netgear.com/t5/x/x/m-p/1854219
Message 2 of 3
mhaselup
Guide
I have a D7000v2 and I think my problem is very similar to yours https://community.netgear.com/t5/DSL-Modems-Routers/D7000v2-requires-reboot-at-least-every-7-days/m-...
I think it's likely a firmware issue, I'm thinking about looking at earlier versions but it's going to be a slow task going back and testing one version at a time until it works.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 810 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
