Orbi WiFi 7 RBE973
Reply
D7000v2 noninternet on nbn
AnYu
The model D7000v2
Since I got that model, it works well with nbn company, last week suddenly the internet disconnected and the internet light is off. Contact with nbn company and try everything( restart reset username and password) is still not working. Yesterday the internet light is turn to red. But still no internet
Message 1 of 4
w3wilkes
Prodigy
Re: D7000v2 noninternet on nbn
Sounds like the unit may be defective. If it's still under warantee you might want to get it replaced.
Message 2 of 4
AnYu
cause that will spend nearly one month if i replace the new router
i did call nbn company they said sounds like there is something wrong wiith outside cable. is ther some way i could check which part is wrong?
Message 3 of 4
w3wilkes
Prodigy
Have you plugged in your old device to see if it also has connection issues? Seems like that would identify if the problem was the outside cable (still have connection problems) or the Netgear device (no connection problems with the old device). If connection problems persist with your old device you should be able to have the ISP dispatch a tech to find the problem.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1655 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
