- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7800 Dropping Ethernet Connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
3 years later, this problem still exists. Running latest firmware, up to twice a day all ethernet connections are dropped/unable to access the network. Wifi devices continue to work unaffected. Only way to restore the ethernet devices connectivity is to reboot the router.
https://community.netgear.com/t5/DSL-Modems-Routers/D7800-dropping-LAN-connections/td-p/1017346
https://forums.whirlpool.net.au/archive/2745275
Some others (including myself from 2016) having the same issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7800 Dropping Ethernet Connections
Ethernet Connections are ok but more of a Wifi drop out connection issue, i've done everything by rebooting, updated to the current firmeware 1.0.1.44, changed channels, it still keeps on dropping out, this modem/router was not cheap too and is suppose to be the best.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have exactly the same issue, has happened since i bought the product over 12 months ago! Have to keep turning the router off for a bit then power back on. Very annoying.
Has anyone had any luck fixing this?
