Orbi WiFi 7 RBE973
Reply
D7800 - attached hard drive
MACH100
Hi.
I have activated Readyshare on my D7800 but am having problems accessing a new WD USB hard drive connected to USB1. I tried connecting a USB memory stick into USB2 and this now appears clearly under the available network folders. Please can anyone advise why I am unable to 'see' the WD drive in the same way, and how I may resolve the problem to create a NAS resource.  Many thanks.
Model: D7000v2|Nighthawk AC1900 WiFi VDSL/ADSL Modem RouterD7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 4
Re: D7800 - attached hard drive
A couple of issues, what is this WD USB hard drive? Did you check it here for compatibility?
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
Then there is the SMB angle:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
Remember, Readyshare is crude technology that is not well suited to some NAS applications. A genuine Ethernet device is usually better, albeit more expensive.
Message 2 of 4
MACH100
Mmm, I hadn't realised that the D7800 might be 'picky' about USB3 drives. I had assumed that any good quality drive should be OK - so it is just possible that this is indeed at the route of my problem.  I have an old (and small) USB drive somewhere, I'll look it out and see if that works, and if so, it suggests you may be right.
I bought a Buffalo automatic NAS (500Gb) a few years ago when I was writing up a dissertation and was getting paranoid about losing anything. The Buffalo did the job, but unfortunately the disk was constantly spinning which I thought undesirable in anything that would be left switched on 24/7 to provide NAS.  Obviously a dedicated NAS would be better - but beyond my budget for what will essentially be a backup device.
If the WD drive turns out to be incompatible, I only got it a couple of weeks ago, so potentially I could return it and exchange for a different model;   A shame Netgear don't mention anything about HDD compatibility in their bumf!
Message 3 of 4
Readyshare in general, not just the D7800.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1676 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
