Orbi WiFi 7 RBE973
Reply
D7800 isp username and password setup problem
IL333
Follower
Setting up using genie. Keep getting incorrect ISP user name or password. Please confirm what I actually enter here.
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 2
antinode
Guru
Re: D7800 isp username and password setup problem
> D7800 [...]
   Firmware version?  Connected to what?  ISP?
> Setting up using genie. [...]
   Which "genie"?  Are you talking about an app, or a web browser, or
what?  I'd use a web browser.
> [...] Keep getting incorrect ISP user name or password. [...]
   I don't know what that means.  "Keep getting" what from what?  What
did you do?  What happened when you did it?  As usual, showing actual
actions (commands) with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> [...] Please confirm what I actually enter here.
   "here"?  Where?  Are you talking about BASIC > Internet : Login and
Password, or what?  You should put in what your ISP tells you to use.
   If you're talking about PPP credentials, then are there any special
characters in them?
      https://community.netgear.com/t5/x/x/m-p/1354547
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 679 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
