Orbi WiFi 7 RBE973
Reply
D7800 router sending DNS query for domain “.” 15 times per second
Stevepos
Initiate
Router firmware is V1.0.1.56
I have setup a local Pihole DNS server and pointed my router to it for DNS lookups. There have been 620,000 lookups since I set it up yesterday evening! The Pihole log file is full of lines like these:
Nov 20 11:32:28 dnsmasq[9115]: query[A] . from 192.168.0.1
Nov 20 11:32:28 dnsmasq[9115]: cached . is NODATA-IPv4
 The netgear router 192.168.0.1 is sending 15 DNS lookups per second for the domain "."
 How do I get a fix from Netgear for this? The community seems to be the only way I can raise the issue?
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 3
myersw
Master
Re: D7800 router sending DNS query for domain “.” 15 times per second
I idea what the router is doing. Does not seem normal. I might do a reset and reconfigure.
I run Pi-Hole as well, but I also have it acting as the DHCP server. Doing that you get individual lookups in the log by device and gives the site being contacted.
Message 2 of 3
Stevepos
Initiate
Thanks Bill. Sounds possible. Will hold out for fix though because lot of work entering all the reservations in pi-hole DHCP screen
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1289 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
