Reply
DG632 with WGR614 v9
Lizk
Follower
I was having problems with connection dropping out and tried to upgrade firmware on my DG632 which now won't work at all.  Can I reverse this?  Have you any suggestions on how to get internet access restored?
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: DG632 with WGR614 v9
Hello Lizk
Have you tried to do a factory reset on the modem put using a paper clip or pen on the back on the modem. If you are still unable to get anything to work after a factory reset you may need to contact netgear support. Hope to hear your feedback.
http://support.netgear.com/general/contact/default.aspx
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2005 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
