Reply
DG834G V4 Firmware update fail.
BigTee
Novice
Hi all, wonder if anyone can help.
Had an old Virgin DG834G v4 router hanging around so thought I would update the firmware to DG834Gv4_V5.01.17.img.
All seemed to be going well, the webpage said 100% but the power light was still blinking red/green so I left it. After about an hour it was still flashing so I unplugged it and reconnected the power. The power light now comes on (green) but I can't gain access to it.
Not on default IP. Even plugged directly into laptop can't get any default gateway to show.
Any ideas???
Message 1 of 5
BigTee
Novice
Re: DG834G V4 Firmware update fail.
Don't you find it amazing that even the manufacturer can't be arsed replying to their own support forum????:eek:
Message 2 of 5
richud
Apprentice
google "dg834 unbrick"
Message 3 of 5
akash22
My DG834G is blinking Power and Tick. Please help.
Recovery Tool not working.
TPTF2 not working.
I can google myself, but experts here should provide help directly. Otherwise everyone will only use google and forum experts will loose job.
Message 4 of 5
DarrenM
Sr. NETGEAR Moderator
Hello akash22
Have you tried to do a factory reset on the device? if that dosnt work you may need to contact netgear support the device could be bricked.
http://support.netgear.com/general/contact/default.aspx
DarrenM
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3883 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
