Orbi WiFi 7 RBE973
Reply
DGN2200 WIFI is not working
Tonsy86
Hello guys,
my WI-FI was working fine until today, suddenly i found the light of the WI-FI symbol is off, i tried to push the WI-FI button but the light didn't turned on. and the WI-FI now is not working, and i don't know why and how to turn it back. anyone can help?
Thanks in Advance.
Model: DGN2200v4|N300 Wireless ADSL2+ Modem Router
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: DGN2200 WIFI is not working
Hello Tonsy86
If you log into the modem then click wireless settings you will see 2 check boxes one is to enable the wireless and the other to broadcast the SSID make sure those are both checked.
DarrenM
Message 2 of 4
Tonsy86
Hello DarrenM,
both are enabled, the light of wirless is still off, and the WPS light is on, any sugesstions ?
Message 3 of 4
DarrenM
Hello Tonsy86
You could try to factory reset the router you will lose your settings and have to do the setup again. You can backup your settings by going to Backup settings in the router. To factory reset hold the reset button down for 10 seconds .
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3879 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
