Orbi WiFi 7 RBE973
Reply
DGN2200v4 multiple issues
maac68
Follower
Hello everyone,
    Just purchased the netgear DGN2200v4, and honestly starting to regret it, first updated it to the latest firmware, started expriencing freezing even when idle, so went back to v58 instead of v66, the freezing problem went away. But the internet was unstable. Add to this, I am trying to use DynDns, but it wouldnt update with correct ip !!! reverted back to my old Technicolor Modem 528, all is well. When i tried contacting the support, they asked for proof of purchase, thats when i provided them with the invoice, later the support case #27299694 was closed with no answer ! should i smash it to the wall, or the issues can be resolved ???
Regards
Model: DGN2200Bv4|N300 Wireless ADSL2+ Modem Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: DGN2200v4 multiple issues
Hello maac68
I have sent you a private message about your case.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1799 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
