Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGND3700 BT Infinity and IPV6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-26
08:09 AM
2012-02-26
08:09 AM
I have a 3700 working ok on BT Infinity. I just noticed my IPV6 connection says not connected. When going to the router access page it showes it as disabled?
Does BT Infinity use/allow IPV6 ?? and more importantly do I need it??:confused:
Thanks
Thanks
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-26
08:40 AM
2012-02-26
08:40 AM
Re: DGND3700 BT Infinity and IPV6
question should be asked BT support
IPv6 is starting to roll out by ISP but transition takes years
using IPv4 is still fine . Reason for IPv6 roll out is that tradition IPv4 is running out of IP's
if you have perfectly working network and you should not worried about it
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-26
01:33 PM
2012-02-26
01:33 PM
Do you have a beta installed since if you don't your router is not a dgnd 3700 router.
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-26
02:51 PM
2012-02-26
02:51 PM
Your right Techman
my router is WNDR3700 with 1.0.7.98 firmware
its fed from my BT Openworld Modem. Does that change anything ??
Thanks
Thanks
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-26
03:14 PM
2012-02-26
03:14 PM
Re: WNDR3700 BT Infinity and IPV6
Yeah since any support you get here will not be suited to your needs and you'll confuse some people looking for ipv6 support on this router.
You'd be more likely to ask if your isp supports ipv6 but tagging this dgnd 3700 is just not helpful to anyone.
Message 5 of 5
Announcements
