Reply
DGND3700. Number of wireless connections
Caterhamkid
I have a DGND3700. I don’t know which version. It is a few years old now. I have recently added an Amazon Echo and I have added 6 TP-Link Smart plugs and I have one more I wish to add. I seem to have run in to a limit for the number of wireless connections. I can no longer connect 2 of my laptops and my printer does not always connect. It is a dual band router but the problem seems to be with the 2.4GHz band. I ma 27 devices that need to connect. Not all at the same time. They are spread across the 2.4GHz and the 5GHz band but not all are able to use the 5GHz band. Is this problem normal or do I have an issue with the router? Can anyone suggest a solution?
Message 1 of 3
Re: DGND3700. Number of wireless connections
This may be useful:
How many clients can you connect wirelessly to a NETGEAR router?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Caterhamkid
Thanks for that.
I fiddled around with it all of yesterday evening with no luck. I eventually added my Netgear extender and I was able to connect everything to that with no issues. I think I have an issue with my router so I am now looking at a possible upgrade.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1876 views
  • 0 kudos
  • 2 in conversation
Announcements
