Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGND3700 and 2 Hard Disks
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-15
07:38 AM
2013-01-15
07:38 AM
Hi everybody,
I have a DGND3700 and 2 HD connected to the 2 USB ports.
I would like to use the second HD as a copy of the first one, the only way I have found is to use some application on my pc to drive the synchronicity of all files, but with 2 problems:
- The copy is very slow. I think that the data moves form the first HD to the Pc and then to the second HD, and therefore the speed is limited by the overall wireless speed
- The pc needs to be linked to the network until the end of the copy
Do you have any idea to improve the situation?
Many thanks
Many thanks
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-21
10:56 AM
2013-01-21
10:56 AM
Re: DGND3700 and 2 Hard Disks
I found that the USB ports on the DGND3700v1 were only good for basic drive sharing. Anything more serious, consider a NAS.
If you are copying the contents between two drives, connect both to your Laptop or Desktop.
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-21
02:17 PM
2013-01-21
02:17 PM
Hi, thanks for your answer.
Actually with just a little more speed I would be satisfied.
Thanks again
Thanks again
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-21
02:36 PM
2013-01-21
02:36 PM
No problem.
Whilst a lot more money, I ended up getting a 2-Bay, then later a 6-Bay NAS. I've been very happy with their performance since. I just need to get a Fibre connection then I can really put them to use when I'm away from home by streaming video content.
Internally I have hammered my LAN connection with them and the WiFi gets hammered too.
I have also found that by using an FTP client I can get that little extra speed out of them. You may want to try this last one for yourself.
When using a couple of different Laptops recently, both with 100mb LAN ports, I was able to get them copying content off the NAS at 99%-99.9%. :rolleyes:
Message 4 of 4
Announcements
