Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGND3700 - no WiFi at all
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-04
08:17 PM
2012-03-04
08:17 PM
Hi,
I've had a DGND3700 for about 5 months now and it had WiFi dropout issues from the start, but I saw there were issues on the forums, plugged in a separate WiFi router I had sitting around into the LAN port and waited for a firmware update (hoping it would get sorted out).
5 months later, I'm now running V1.0.0.17_1.0.17 and WiFi doesn't even show up as a blip on inSSIDer. I've turned the DGND3700 off and on several times, turned off/on the wireless several times and reset factory defaults several times but none of it has made a difference. The LAN ports work fine, ADSL is fine and 2.4Ghz & 5Ghz LEDs are on but there is nothing being broadcasted (SSID is set to broadcast and I've tried using specific channels and Auto channel with no effect).
Has anyone else come across this, have any suggestions on what may be happening or better yet have a suggestion on how to get it working?
Many thanks,
Ben
Many thanks,
Ben
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-04
08:30 PM
2012-03-04
08:30 PM
Re: DGND3700 - no WiFi at all
Contact support for RMA exchange. Sounds like defective unit
Use portal at my.netgear.com.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-05
04:07 PM
2012-03-05
04:07 PM
Thanks, I've logged a support case with Netgear and will see what happens.
Cheers,
Ben
Cheers,
Ben
Message 3 of 3
Announcements
