Orbi WiFi 7 RBE973
Reply
DGND3700 port forwarding issues
jaymesmcc
Hello,
I recently bought a DGND3700 Gigabit router/modem and have enabled port forwarding for a single port (TCP) allowing my Slingbox to operate smoothly.
Previously I used an Orange Livebox and although the connection wasn't as fast it was very consistent.
Since purchasing the Netgear it has lost it's port forwarding settings around once a week. Although when I look at port forwarding on routerlogin.com it appears the TCP setting is still active (and the slingbox has the same IP address - I can check that on the actual Slingbox) the Netgear does not port forward the feed.
I usually have to do a complete reboot which is also very inconvenient.
I have read about previous connection issues with this router but as I have firmware version 1.0.0.17 I assumed all of these glitches had been solved?
Has anyone experienced anything similar?
Thanks,
J.
Message 1 of 2
Scubbie
Apprentice
Re: DGND3700 port forwarding issues
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 8395 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
