Reply
DGND3700 port forwarding
map7
I've just upgraded from an old DGN2000 to the DGND3700 and I cannot get port forwarding working under this new router. I'm running firmware 10.0.0.12_1.0.12 which is the latest.
I'm just trying to get ssh access for a start to an internal PC on the network through port forwarding.
First I've setup a Custom Service under Port Forwarding for SSH with start port 22 & end port 22 and then I put my PC as the server IP address. I have the sshd running and tested on my PC.
I've tried changing some settings in Advanced -> WAN Setup.
NAT Filtering I changed from Secured to Open, no change, even after rebooting the router.
If I toggle the Respond to Ping on Internet Port then from an outside computer I can now ping my external address. So I've tested that the external address is correct and that I can influence something about the router.
I've tried turning on the 'Default DMZ Server' and pointing that to my computer just to see if I can by-pass the firewall.
I've checked to make sure my firewall at the ISP level is off and I know this was working on the old router.
Is there anything special to do with the router stopping me from port forwarding a simple ssh service?
Message 1 of 5
jmizoguchi
Virtuoso
Re: DGND3700 port forwarding
you are not testing behind the route are you? loopback will cause the failure.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
map7
I'm always testing from a remote server. First I ssh out of the building to a server, then I try and ssh back in through the outside IP address as stated in the Router status page.
from
Michael
Message 3 of 5
map7
I was ssh in to my office and back out again using the outside IP address mentioned in the Router Status page. This morning I tried connecting to it via my phone and it worked. Seems like the new firewall at work is restricting me a little too much. Problem fixed, thanks.
Message 4 of 5
jmizoguchi
Virtuoso
Propel forget about remote end issue and feels more issues on one side only
Glad you figure it out... Enjoy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 13325 views
  • 0 kudos
  • 2 in conversation
Announcements
