Orbi WiFi 7 RBE973
Reply
DGND3700 with Apple Airport Extreme in Bridge Mode - no LAN access ?
speedcheese1
Follower
I have an Apple Airport Extreme Base Stations (AEBS) connected to my primary Router (Netgear DGND3700). This, in turn, is connected to a cable modem. So the setup is:
Internet > Cable Modem > DGND3700 > AEBS
The cable modem is literally just that - acts as the gateway out to the internet.
The Netgear router acts as the DHCP server to the network and the AEBS connects one of the LAN ports of the Netgear to the WAN port of the AEBS. The AEBS is set up as Ethernet in Bridge Mode.
If I connect to the AEBS either wired or wifi, I can see all other devices connected to the AEBS on the network and if I click on any, I can browse shared folders etc. If I connect to the Netgear router I cannot ping, traceroute or connect to any AEBS devices. I suspect it's something to do with internal routing but I can't find a setting on either device where this may being blocked.
Anyone got any suggestions what I'm missing or what I might try ?
Thanks in advance.
Message 1 of 3
Scubbie
Apprentice
Re: DGND3700 with Apple Airport Extreme in Bridge Mode - no LAN access ?
The Airport Extreme is a router in it's own right. If you have connected it via it's own WAN port, then this is why you cannot access anything on the AE when connected via the DGND3700.
I would suggest that you connect the AE via an Ethernet port and ensure that you have disabled it's own DHCP Server abilities.
Message 2 of 3
jmizoguchi
Virtuoso
This is the concept you need to follow
http://kb.netgear.com/app/answers/detail/a_id/965
wether you are suing Mac or PC, there is airport utility under
Finder>application>utilities> airport utility (Mac system). I'm sure for Pc are simple as open the application
you need to change according like the URL given for "concept.
Airport extreme as internet port and Lan ports. they do not have "word" saying but just by symbol so you may need to look manual that came with it but do NOT use WAN or internet port .
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 13720 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
