Orbi WiFi 7 RBE973
Reply
DGND3700v2 Latency problem with iMac 27" running OS Sierra 10.12.6
tripod74
First time poster, a bit naive on all this so please bear with me.
Purchased new iMac and new router in Jan 2014. The last several weeks I have been having big problems with internet connections. Painfully slow to load, intermittent unable to connect etc. Speed tests on other home devices (iPhone, iPad show acceptable DL speed of 6-7 mbs while regularly iMac shows less than 1 mps and often the test fails.
Have spent hours on calls with Apple and my IPS without success.
Could this be a wifi card problem?
Don't know where to turn - hope there is help in this Community. Thanks.
Model: DGND3700v2|N600 WIRELESS DUAL BAND GIGABIT ADSL2+ MODEM ROUTER
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: DGND3700v2 Latency problem with iMac 27" running OS Sierra 10.12.6
Hello Tripod74
If you are connected via wireless try a ethernet cord and see if the speed test is any better. also did you notice the slowdown after anytype of update on the PC or some setting you changed?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 418 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
