- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGND3800B AnnexB CAN be switched to AnnexA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DGND3800B AnnexB CAN be switched to AnnexA
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would like ask a question about this device maybe not so close about the topic but I couldn't a closer topis about my question.
Is it possible to use this device, DGND3800B simply as a vdsl modem? Is it possible to switch the device into bridge mode? I would like use it this way because i would like to use my Mikrotik router as a router and this Netgear box as a modem before that.
is it possible?
Thanks
cyd
- Mark as New
- Bookmark
- Subscribe
- Permalink
can you also please tell me the firmware for the netgear 3800B provide for itlalien?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@PaaNooS - I sent you the link. All languages already incuded in he firmware by Netgear
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought the DGND3800B in Germany thinking it is Annex A, but unfortunately it doesn't work in my POTS connection.
LuKePicci , please send me the link to your firmware (English).
Many thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem with italian ISP.
Can I please have the link for the annex A firmware vs.?
Thank you in advance.
KeBerin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please send me the link to your firmware.
Is it possible to choose your firmware annex, or just to annex a?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Luke, have you already compiled the latest firmware (v3.0.0.12)
for 3800B with Annex A compatibility?
Please E-mail me the link & password.
Best regards.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just tried to start telnet (to adjust snr) and is not possible.
Is there any hope we can get snr adjustment in another firmware version?
Many thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you think it would be possible to have all the features of the richud fw but
for ANNEX B (doesn't matter for me if ADSL only or ADSL/VDSL)?
I currently live in Germany and I kinda need the B version 🙂
Once again, thank you for the great work!
- Mark as New
- Bookmark
- Subscribe
- Permalink
LuKePicci - I have sent you a PM. Would be greatly appreciated if you could send me the link to the Annex A firmware. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm still debugging rev6 issues with telnet daemon taking randomly all CPU res. If someone who flashed rev6 has random performance issues just let me know and I will send you rev5 (with locked telnet).
PS: Happy new year :cool:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you already compiled any stable firmware for DGND3800B with telnet enabled?
I just saw a new firmware v3.0.0.16 (German Users Only) is out.
Best regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
DS: (65,857) (1218,1959) vs. DS: (73,857) (1218,1959) (2795,3253)
3800B using both annex B or annex A fw
/ # xdslctl info --pbParams
xdslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 14880 Kbps, Downstream rate = 48056 Kbps
Bearer: 0, Upstream rate = 14747 Kbps, Downstream rate = 44665 Kbps
Discovery Phase (Initial) Band Plan
US: (32,63) (882,1193) (1984,2770)
DS: (65,857) (1218,1959) (2795,4083)
Medley Phase (Final) Band Plan
US: (32,63) (882,1193) (1984,2756)
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 14880 kbps 48056 kbps
Actual Aggregate Tx Power: 9.2 dBm 13.2 dBm
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 9.6 36.0 53.0 N/A N/A 18.5 43.6 64.4
Signal Attenuation(dB): 9.6 35.9 52.7 N/A N/A 18.5 43.6 N/A
SNR Margin(dB): 6.6 6.0 6.2 N/A N/A 6.3 6.2 N/A
TX Power(dBm): -3.8 5.7 6.2 N/A N/A 11.7 7.9 N/A
AV4202N A1 austria 3.0.10 fw annex a
root@vdsl2:~# xdslctl info --pbParams
Status: Showtime
Last Retrain Reason: 1
Max: Upstream rate = 14193 Kbps, Downstream rate = 48295 Kbps
Bearer: 0, Upstream rate = 5800 Kbps, Downstream rate = 48285 Kbps
US: (32,63) (882,1193) (1984,2713)
Attainable Net Data Rate: 14193 kbps 48295 kbps
Actual Aggregate Tx Power: 8.4 dBm 13.5 dBm
Line Attenuation(dB): 9.1 36.6 53.8 N/A N/A 18.9 44.7 67.4
Signal Attenuation(dB): 9.1 36.5 53.6 N/A N/A 18.9 44.2 68.1
SNR Margin(dB): 15.4 15.1 11.6 N/A N/A 6.3 6.2 6.3
TX Power(dBm): -3.7 5.7 4.5 N/A N/A 11.7 8.1 1.6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi LuKePicci1,
I made the same misstake by bying the DGND3800B model in Germany and taking it home to South Africa not considering at that time whether I need Annax A or B. Could you please help out and make your Firmware build available to me? My Netgear model is *DGND3800B-100GRS*
Kind regards
Jovan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Luke!
I bought the dgnd3800b in Germany and the modem isn't working in Greece ( annex A ADSL).
I have it 2 years gathering dust and i would like to make use of it now!If you are kind enough to sent me a lick of the annex A
firmware i'll much appreciate it !! Thanx !
- Mark as New
- Bookmark
- Subscribe
- Permalink
@22athadsl could you please try my firmware so see if the annex change is ok, I don't have anyone who tested it is ok yet.
http://www.richud.com/wiki/DGND3700_V1_Transmission_Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I live in India and while I was in Germany in Dec 2015 I bought Netgear D6200B not realising it is an Annex B modem. In India we have ADSL over PSTN i.e. Annex A. Can D6200B be switched to Annex A by changing the firmware to Annex A router. If it is possible can someone post the firmware to be uploaded so that the router works in Annex A. Thanks in advance. I have also started a separate topic https://community.netgear.com/t5/DSL-Modems-Routers/Can-D6200B-AnnexB-be-switched-to-AnnexA/m-p/1053... .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Could someone please clarify whether the DGND3700 and DGND3800 are EXACTLY the same hardware or not ? Is the POTS (Annex A) and ISDN (Annex B) distinction purely a difference in terms of software or firmware ?
RichUD: In your customized firmware can you effectly switch between the two versions ?
Thanks in advance for the help!
