- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGND4000 connecting Fibre & vlan setting
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have changed from ADSL to Fibre and was going to use my existing NGND4000 \ N750 as it has it has an Ethernet wan port.
However my ISP requires the WAN port to be on vLan 10 and I can't find any vLan setting at all.
Is there a way I can configure it or a firmware upgrade to make that option available ? It used the same Broadcom base chipset as the newer D6x00 routers that do seem to show that option.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DGND4000 connecting Fibre & vlan setting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you have any luck setting up VLAN setting on the DGND4000? I have a similar issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have access to your ISPs modem settings/configuration you can set up a DMZ with an IP address that is your DGND4000. The ISP router then simply manages the connection only, and pushes all internet traffic (without applying any firewall rules etc) to your Netgear Router. All the rest of your tech in the house will continue to connnect to the DGND4000 as normal.
I have done this with both a Sky SR102 and BT Openreach HG612 in the past. You connect a Lan cable from any port of the ISP router to the WAN port of your Netgear
Check the forum here for an idea of how to do it
http://www.skyuser.co.uk/forum/asking-help/42110-using-dlink-dir613.html
Hope this helps
