- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DM200 bridge mode is full bridge mode or only semi bridge mode ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi ,
I set up DM200 as bridge mode, it is full bridge mode or only semi bridge mode ?
Thanks, see you.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DM200 bridge mode is full bridge mode or only semi bridge mode ?
When the DM200 is in Bridge mode it my experience in the UK
1) disables the internal Firewall
2) does not perfrom NAT
3) Bridges the XDSL PPPoA to PPPoE onto the Ethernet port. The device connected onto the Ethernet port must support a PPPoE (Point toPoint Protocol Over Ethernet) and be configured for your ISP provided Username and a Password. For BT in the UK this is username "Bthomehub@btbroadband.com" password "pass" the password can be left blank. The Connected device then via the PPPoA to PPPoE bridged connection will be given your ISP provisioned outside IP address and also the DNS ip addresses. AT this stage the attached device should be perfoming the Network Address Translation (NAT) for you internet connetion.. Internet security etc The DNS addresses are normaly then sent to your network via DHCP configurations.
In my cases its quite simple
Internet ------VDSL2 ------- DM200 ----- PPPoE ----- Untangle UT security ------- Intenal network 192.168.x.x
- Mark as New
- Bookmark
- Subscribe
- Permalink
It should be fully bridged.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
What else is connected?
A router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @michaelkenward ,
A router?
Yes a router.
See you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
