- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DSL Light amber
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. Not sure if the is is the right sub-board but here goes. I bought a D7800 as drop-in replacement for a DGND-3300.
I put it all together as per the quick start instructions.
I initally used the microfilter and cable from the previous router. However the DSL light (twisted flax symbol) stayed amber.
I checked the connections and they were all fine.
So I changed the microfilter and cable to that supplied with the D7800 and still an amber DSL light.
I went on the Netgear support site and it said I needed to plug the router into a modem. However the quick start guide specifically shows a set up diagram where the router is plugged into a microfilter and not a modem.
Out of the need to contact this community and also to get the internet back, I dropped the DGND-3300 back in with the microfilter and cable from the d7800. This is working fine.
Please advise.
Many thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
try the dsl forum. You'll get the people who know more about dsl. This is for wifi 6 router.s
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
