- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Dgnd3700 VPI VCI settings Centurylink Sioux Falls SD.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am planning to purchase the 3700 modem/router. From the specifications I have read this is the equipment I want to install. The one issue it finding the correct VPI/VCI settings. Centurylink support is somewhat oblivious to the question, since I am not using one of there recommended modems. I will continue to push the issue until I receive an answer.
Actually I was wondering if the 3700 had the capability of determining these settings. If not maybe someone on the thread that lives in my area can provide the information.
Thanks John
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Dgnd3700 VPI VCI settings Centurylink Sioux Falls SD.
I'm guessing you're talking ADSL and not VDSL. The DGND3700v2 only does ADSL. The settings should be;
For Centurylink ADSL here's the settings;
- ISP Protocol: PPPoE
- Authentication Protocol: CHAP
- Enter the PPP Username
- Enter the PPP Password
- Line Mode: Auto
- Set the VPI to: 0
- Set the VCI to: 32
- Encapsulation: LLC/SNAP
- Static IP address: NOT checked
- MTU: 1492
As far as I know the VPI VCI will not be auto detected. Here's where I got the settings...
http://internethelp.centurylink.com/internethelp/modem-3rd-party-q.html
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks W3..., I can't believe that the solution was on the CenturyLink web site. I guess I have been so down on CenturyLink customer service, if it can be called that, that I don't think they provide good solution/information on there web site. We are renovating our home/office and when it is finished I will do the install.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OOPS...
I made a little mistake, I need a VDSL (2) modem. So it looks like I will start my quest for a DSL modem with the correct specs.
Thanks again, John
