Orbi WiFi 7 RBE973
Reply
Does a firmware update on a D6400 delete any port forwarding settings
Tarm1
If I update firmware on my D6400 will it wipe any port forwarding settings?
thanks,
Tarm
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: Does a firmware update on a D6400 delete any port forwarding settings
> So, do you use the Netgear Genie app to access those settings or the
> web address of the router? The Genie keeps timing out when I enter what
> I think is the password and email address.
   I generally stick with a web browser on a conventional computer
(normally Firefox on a Mac).  I have enough problems with the Netgear
router firmware that adding another layer of Netgear "app" software has
never appealed to me.
   My iPad use (iPad 2, 9.3.5) has been slight, and my expertise is
similarly weak, but I've never seen a user-accessible file system on the
thing, so, even if I could find a way to save a web page in Firefox (or
Safari), I wouldn't know where to find it later.  Nor would I know how
to deal conveniently with a simple text file there.  On a conventional
computer, it's all easy.
Message 4 of 4
All Replies
antinode
Guru
> settings?
   It's never happened with my D7000[v1].  It shouldn't, but, without
access to the source code, who could be sure?
   I'd save the ADVANCED > Advancd Setup > Port Forwarding / Port
Triggering web page, so that recovery using copy+paste would be easier.
(What I actually do is maintain a text file with such settings, and
copy+paste from that into the router web forms when I configure it.
But, if you don't have such a file, then saving the web page should be
pretty close.)
Message 2 of 4
Tarm1
Thank you for the reply!
So, do you use the Netgear Genie app to access those settings or the web address of the router? The Genie keeps timing out when I enter what I think is the password and email address.
i’ve tried recovering my password thinking I maybe put in the wrong one, but I still get the timeout. I am on iPad running iOS 11.3.
Thanks,
Tarm
Message 3 of 4
antinode
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1057 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
