Orbi WiFi 7 RBE973
Reply
Enable telnet on D6400D (AC1600 WiFi VDSL/ADSL) firmware D6400-V1.0.0.104_1.0.104.
DG834GIT
Hi guys.
I noticed that with the latest firmware D6400-V1.0.0.104_1.0.104 released for the D6400, the utility telnetenable.exe (https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe) to access the configuration of the router parameters via BusyBox no longer works, the latest firmware release operating with telnetenable.exe is the D6400-V1.0.0.96_1.0.96.
It is a pity that Netgear has not provided for a way to be able to access the operating parameters of the D6400 and now has blocked the possibility of accessing BusyBox via telnetenable.exe, since in some cases be able to change some parameters (such as SNR) could fix connection problems.
Having said that, is there someone who knows how to run telnetenable.exe with the D6400-V1.0.0.104_1.0.104 firmware, or other method to access BusyBox or in any case change the D6400 router parameters, without necessarily downgrade to the D6400-V1.0.0.96_1.0.96 firmware release?
Thanks in advance.
Fabio
Model: D6400|AC1600 WiFi VDSL/ADSL Modem Router?802.11ac Dual Band Gigabit
Message 1 of 3
antinode
Guru
Re: Enable telnet on D6400D (AC1600 WiFi VDSL/ADSL) firmware D6400-V1.0.0.104_1.0.104.
Different model, similar complaint:
      https://community.netgear.com/t5/x/x/m-p/2060436
> [...] is there someone who knows how to run telnetenable.exe with the
   Not I.  I assume that when they break it, they break it for every
similar program.  If they've changed the requirements for an Enable
program, then I haven't seen the revised spec.
   When they break it on the D7000[v1], I'll be annoyed.
> [...] be able to change some parameters (such as SNR) could fix
   Huh?  I'd call SNR a property of a comm channel, not an adjustable
parameter.
Message 2 of 3
DG834GIT
parameter.
Of course SNR refers to the limit value of the noise margin negotiated by the modem-router while synchronization.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 836 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
