Reply
Highlighted
Follower
Faulty Port Forwarding on D7000 Nighthawk
Why won't my D7000 allow me to open more than one port?
I have set one forwarding rule to a LAN device and when I check for the open port using http://www.yougetsignal.com/tools/open-ports/ and http://www.canyouseeme.org/ the port is reported as open.
I then set another rule for a different port for a different LAN device and yougetsignal and canyouseeme says the port is closed. No matter what port number I use or LAN IP I point it to, I cannot get more than one port open. I've ticked the "Disable Port Scan and DoS Protection" so I can perform port scanning. I have disabled HTTP access to the Readyshare because I'm port forwarding port 80 to another LAN device. I have rebooted the router after every rule change/entry. I have also disabled NAT Filtering.
This is driving me nuts. I do port forwarding every day for my clients, so I don't believe I'm doing anything wrong, but hey, I'm open to suggestions.
Router firmware is V1.0.1.44_1.0.1
Any help please will be much appreciated.
Message 1 of 3
Highlighted
NETGEAR Moderator
Re: Faulty Port Forwarding on D7000 Nighthawk
Hello Jesse_s
port 80 is reserved on the router and can not be forward.
DarrenM
Message 2 of 3
Highlighted
Tutor
I have port 80 forwarded in my D7000 to a raspberry pi on my internal network (192.168.1.148)
Message 3 of 3
Discussion stats
  • 2 replies
  • 3375 views
  • 0 kudos
  • 3 in conversation
Announcements
