- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware update
I have unsuccessfully tried to install the latest update. I get well progressed with the update then I receive a message "can't connect to site routerlogin.net" but my internet is working fine and I am connected to the modem by cable. I have no problems updating my nighthawk X10 router.
How do I solve this problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware update
What is the model of the wireless router?
What is the firmware version?
You can manually update the firmware of the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware update
The model is DGN2200v4 a N300 wireless ADSL+modem router
The Firmware Version is V1.0.0.98_1.0.98
Please refer to the attachment. I can access the modem. I can initiate the firmware upgrade. Everything seems to be going fine then I receive an error message yet I still have internet access (before trying to undertake th eupgrade I shut down all other internet connected devices. Help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware update
Hi shepsonlinee,
Have you tried manually updating the firmware? If not, I would recommend upgrading the firmware manually. Make sure the computer is connected wired to ADSL modem/router local port and access the default IP as 192.168.0.1.
https://kb.netgear.com/000054783/DGN2200v4-Firmware-Version-1-0-0-102-All-Regions-Except-Germany
If you have another NETGEAR router connected into ADSL modem/router, this might cause the issue when you performing the firmware upgrade.
Thank you,
Mary
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware update
Thanks problem solved. Not sure if the problem was, possibly Windows Defender was blocking the update (strange that I can updatethe router with no issues). Any way thanks for all your help - much appreciated.
