Reply
Is it required for me to buy a modem and wifi router?
MaldonadoEJ
I am wondering if I need a DSL or Cable Modem for to connect with the internet? I am currently still thinking to buy the new NightHawk WiFi Router and I am guessing if I need a new modem to my new NightHawk wifi to connect wifi. I'm not sure if I need one or not. I want a specific, professional answer with details about modem and wifi routers differences please and thank you. Smiley Happy
Message 1 of 6
Accepted Solutions
Re: Is it required for me to buy a modem and wifi router?
@MaldonadoEJ wrote:
My point is, is it required to buy a modem to connect the internet/WiFi with the WiFi router?
We all need something to connect us to the internet. But what the box we use to do it depends on the sort of internet that you sign up for.
Some of us get internet over the telephone system using a service called DSL. Other gets it through a dedicated cable into the building. Really flashy service come with an optical fibre to the front door. There are even some people who have a satellite link. Some people use a mobile phone network. All of these need different "front end" hardware.
So you'll have to work out what sort of service local internet companies provide in your area. When you know that you can start looking for a modem. You might even find that the Internet service provider (ISP) "gives" you a modem for its service.
Most makers of network kit sell devices that combine modem and router functions in a box that delivers wifi and local wired connections.
The combined modem/router is easier to set up, but some people like to have separate modems and routers. Then we can get a better router with more features. Then we buy a basic modem that has none of the bells and whistles it takes to deliver local wifi and network access.
A good place to start is with the neighbours. If you can find someone with internet access, ask then what they use. Then take things from there. But check to see how many companies offer internet services in your area. You may have a choice.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 6
All Replies
antinode
Guru
> internet? [...]
   You probably need _something_, but what that should be depends on the
service which your Internet Service Provider (ISP) provides.
> [...] I am guessing if I need a new modem to my new NightHawk wifi to
> connect wifi. [...]
   Do you have an _old_ modem?  Do you currently have an ISP or a
router, or are you starting from nothing?
> [...] I'm not sure if I need one or not. [...]
   Same here.
> [...] I want a specific, professional answer [...]
   Then you should start with a clear, specific description of what you
have now, and what you want to do next.
> [...] with details about modem and wifi routers differences [...]
   If you want a complete explanation of the Internet, and how to get
connected to it, then a forum like this may not be the best place to
begin.  For example, no one here knows where you are, nor which ISPs
serve your region, nor anything else about your situation, requirements,
budget, ...
Message 2 of 6
MaldonadoEJ
Message 3 of 6
antinode
Guru
   My point is that your question makes no sense.  I don't know what
"the internet/WiFi" means to you.  It might help if you answered my
questions instead of asking more of yours.
Message 4 of 6
Just another user.
Message 5 of 6
MaldonadoEJ
Thanks, this really helped me out to your respectful response. I will figure the rest out, I just needed a headstart to begin with. Thanks again. Smiley Happy
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1182 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
