Orbi WiFi 7 RBE973
Reply
Login to D6400 via https or SSL for administration
Oneis
Follower
Does the D6400 support admin login via https or ssl?
If not, how do I administer the router securely without having to connect via ethernet cable?
Thanks!
Model: D6400|AC1600 WiFi VDSL/ADSL Modem Router?802.11ac Dual Band Gigabit
Message 1 of 2
antinode
Guru
Re: Login to D6400 via https or SSL for administration
   Apparently not.  Perhaps some day.
   I'd expect the usual encryption used by the wireless networking to
satisfy that requirement.  The real problem would be remote access from
the outside world (if that's enabled).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 669 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
