Orbi WiFi 7 RBE973
Reply
Login to D7000 - works on wifi but not on switched ethernet
walaj
Guide
Any reason my D7000v1 will allow me to login to the GUI on wifi, but no if I'm connected via ethernet (via a switch)?
I have zero issues with internet access, and I can telnet to cli with no problem on wired and wifi.  Switch is an unmanged TP-Link 24 Port Gig-E
When accesing the web GUI via wired connection, I'll get a request for authentication, but zero response there after.
ethernet
(! 35)$ wget http://192.168.1.254/ --user=admin --password=password --timeout=20 --tries=3 --verbose
--2018-09-21 14:54:31--  http://192.168.1.254/
Connecting to 192.168.1.254:80... connected.
HTTP request sent, awaiting response... 401 Unauthorized
Authentication selected: Basic realm="NETGEAR D7000"
HTTP request sent, awaiting response... Read error (Operation timed out) in headers.
Retrying.
--2018-09-21 14:54:52--  (try: 2)  http://192.168.1.254/
Retrying.
--2018-09-21 14:55:14--  (try: 3)  http://192.168.1.254/
Giving up.
on wifi:
(! 36)$ wget http://192.168.1.254/ --user=admin --password=password --timeout=20 --tries=3 --verbose
--2018-09-21 15:21:51--  http://192.168.1.254/
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: ‘index.html’
index.html                                    [ <=>    ]   6.26K  --.-KB/s    in 0s
2018-09-21 15:21:51 (436 MB/s) - ‘index.html’ saved [6406]
Model: D7000v1|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 4
Accepted Solutions
walaj
Guide
Re: Login to D7000 - works on wifi but not on switched ethernet
seems my mitm box is potentially eating packets. But only the first few packets, meaning the web browser doens't get a valid html response.
my issue though, presumably not the router.
Message 4 of 4
All Replies
antinode
Guru
   Nothing leaps to mind.  I seem to have no such trouble:
ITS $ wget dsl --user=admin --password=password --timeout=20 --tries=3 -v
Conversion from 'ASCII' to 'ASCII' isn't supported
--2018-09-21 01:03:38--  http://dsl/
Resolving dsl... 10.0.0.1, 10.0.0.1
Connecting to dsl|10.0.0.1|:80... connected.
Saving to: 'index.html'
2018-09-21 01:03:38 (125 KB/s) - 'index.html' saved [6406]
   Around here, that's V1.0.1.68_1.0.1 (freshly updated), and:
ITS $ wget --version
GNU Wget 1.18a built on VMS IA64 V8.4.
-cares +digest -gpgme +https +ipv6 -iri +large-file -metalink -nls
+ntlm +opie -psl +ssl/openssl
Wgetrc:
ITS $ tcpip show version
  HP TCP/IP Services for OpenVMS Industry Standard 64 Version V5.7 - ECO 5
  on an HP rx2600  (1.50GHz/6.0MB) running OpenVMS V8.4
   Do you get the same result from a GUI web browser?  The worst
behavior I could manage was:
--2018-09-21 01:08:04--  http://dsl/
index.html              [ <=>                ]   6.65K  --.-KB/s    in 0s
2018-09-21 01:08:04 (133 KB/s) - 'index.html' saved [6807]
ITS $ search index.html currently
        <p><span languageCode="10008">You are currently logged in from another d
evice. There can be only one device logged in at a time. If you log in from this
 device, the other device will be logged out. Do you want to proceed?</span></p>
But, as you can see, even that didn't time out.
   The D7000 (port 1, others unused) goes to only some (Netgear?)
24-port Gb switch, one port of which goes to a port on some cheap 8-port
switch; another port of the 8-port switch feeds a Gb Ethernet interface
on the computer.  (None of which should matter at all.)
Message 2 of 4
walaj
Guide
Hmm.
OK - I do have an active "filter" (work box, does traffic shaping/filtering/monitoring), however it isn't supposed to be doing anything to this traffic.
Bypassed the filter - works straight away.
Stumped why the filter would be impacting it though, given it doesn't appear to be altering anything else.
Message 3 of 4
walaj
Guide
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1364 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
