Orbi WiFi 7 RBE973
Reply
My IP changed does it matter? Is it a VPN?
whistlingjack
Follower
After I installed myN600 wireless router i found that as far as the internet was concerned I had moved serveral hundred miles. Previoulsly when I used "Whereisip.com" my IP was in southwest Washington State. Now it showes some place in Kansas. Does it matter? Is this like a VPN?
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: My IP changed does it matter? Is it a VPN?
Hello Whistlingjack
This sounds more like the proxy settings had been changed making your ip look like its a different location. I would check to see if proxy settings have been changed if not reboot your modem and routers check again if still seeing a IP not close to you i would contact your isp and troubleshoot with them.
DarrenM
Message 2 of 2
All Replies
DarrenM
Hello Whistlingjack
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3220 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
