Reply
NETGEAR D7000 AC1900 VDSL2 Profiles
tomergi
Follower
I want to buy the D7000, but I wonder what VDSL2 profiles it supports. Does it support 30a or 35b? Will it provide 200Mbps over VDSL2?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
antinode
Guru
Re: NETGEAR D7000 AC1900 VDSL2 Profiles
> I want to buy the D7000, [...]
   Why?
   D7000[v1] or D7000v2?  Look for "Model" on the product label, or
"x" in a "-x00rrr" suffix on the SKU on the package.  For example,
"D7000-100NAS" for a D7000[v1].
> [...] Does it support 30a or 35b? Will it provide 200Mbps over VDSL2?
   I doubt it.
   Visit http://netgear.com/support , put in the model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Technical
Specifications" and "xDSL data rate".
   A Web or forum search for these models should find abundant other
reasons to avoid them.
Message 2 of 3
Which Internet service provider do you plan to use?
Have you looked for a list of compatible hardware for that ISP?
In general, experienced uses go for separate modems and routers. In that way you can get a router with a wider range of features, and one that is updated with security features and added features more often than combined devices. The challenge is to find a DSL modem/only device as kit makers seem to be pulling out of the market.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 319 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
