Reply
NETGEAR GENIE D3600 FIRMWARE PROBLEM
GEORGE_G
Follower
Hello everyone!! Αfter a power cut in my area, the modem D3600 resetted to the factory settings without allowing any change in the choice of the region and the wireless settings. Also it does not accept the apply setting and does not display the 5ghz band...
p. s. the firmware is 1.0.0.72.
Any solution??
Model: D3600|N600 WiFi Modem Router - 802.11n Dual Band Gigabit
Message 1 of 2
antinode
Guru
Re: NETGEAR GENIE D3600 FIRMWARE PROBLEM
> [...] After a power cut in my area, the modem D3600 resetted to the
> factory settings [...]
   Or, it corrupted the settings in some other way.  I'd try an
intentional settings reset, and see if that changes anything.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Factory Settings".
   V1.0.0.75_1.0.1 seems to be current.
for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 429 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
