Orbi WiFi 7 RBE973
Reply
NETGEAR High-Speed Broadband DSL Modem (VDSL ADSL) - Compatible with BT, Sky, Virgin, Talk Talk, Vod
BigBobG57
I'm looking to purchase one of the above but I have noticed that my BT modem has a network connection from the master box, a network connection to the router and a small phone connector inot the back on the unit. Do I need to use the phone connector on the modem?
Model: DM200|Broadband High-Speed DSL Modem
Message 1 of 13
antinode
Guru
Re: NETGEAR High-Speed Broadband DSL Modem (VDSL ADSL) - Compatible with BT, Sky, Virgin, Talk Talk,
> I'm looking to purchase one of the above [...]
   Assuming that "the above" is a DM200, why?  What is the actual
problem which you are trying to solve?
> [...] my BT modem [...]
   What is it?  Maker?  Model?
> [...] has a network connection [...]
   Define "network connection".
> [...] from the master box, [...]
   What is it?
> [...] the router [...]
   What is it?
> [...] a small phone connector inot the back on the unit. [...]
   Labeled how?  Connected to what?
> [...] Do I need to use the phone connector on the modem?
   That might depend on what it is.
   Presumably, DSL service would involve some kind of telephone-like
connection, but your description of this stuff is so vague as to convey
practically no useful information.
Message 2 of 13
BigBobG57
BT 's UK FTTC (VDSL2/Infinity) May be Huaweii
1.   A  "network connection" to my router Asus AC66.
2   Back to the BT master phone box
   Master incoming telephone box UK
Asus AC66
RJ11 plug from master box
Message 2 of 2
THat's what I'm wondering,  the BT Modem has 1 RJ11 connection from the master phone box, 2 RJ45 connections one to the master phone box and one from there to my main router
Message 3 of 13
BigBobG57
The DM200 has two conections, are they both RJ45 or is one an RJ11 and will it make any difference not connecting one
Message 4 of 13
antinode
Guru
> [...] May be Huaweii
   Huawei makes many things.
> [...] the BT Modem has 1 RJ11 connection from the master phone box, 2
> main router
   Are any of these ports labeled?
   Knowing nothing about your "the master phone box", I could only guess
at the purpose of the "RJ45 connection" (Ethernet?) between it and your
"the BT Modem".
   Here's a radical concept:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in the model number, and look
for Documentation.  Get the User Manual.  Read.  The picture may be a
little misleading ("VDSL" port too big), but the text is pretty clear:
      LAN port. One Fast Ethernet RJ-45 LAN ports to connect the modem
      to a LAN device such as acomputer, router, WiFi router, or
      Ethernet switch. This port is colored yellow.
      VDSL port. One RJ-11 DSL port for connecting the modem to an ADSL
      or VDSL line. This port is colored gray.
   Presumably, a DM200 could handle your data connection, but if the
(unspecified) "the BT Modem" has a special RJ45 port for voice service,
which is expected by your (unspecified) "the master phone box", then the
DM200 might not do everything you want.
Message 5 of 13
@BigBobG57 wrote:
I'm looking to purchase one of the above but I have noticed that my BT modem has a network connection from the master box...
If you have BT's DSL, then you can bin the BT modem.
You just plug the DM200 into the phone socket instead of the BT modem/router.
If you don't have DSL, then the DM200 is no use.
But do that and you will need a router if you need wifi or anything but the simplest of networks. If you do buy a separate router, the DM200 has some basic router features so you should put it into modem only mode before you attach the router.
Most BT modem/routers do not have a simple "modem only mode". I have never investigated using one as a router without the modem. The only documentation I have for mine suggests that it lacks the WAN port that you will find on some other modem/routers.
Out of interest, why do you want to get rid of the BT box? They aren't very good – I have one sitting in its original shrink wrap – and lack the controllability of many routers. But I wouldn't change it just for the hell of it.
Message 6 of 13
BigBobG57
I've tried setting the modem in 'modem only' mode but the network refuses to recognise this.
As I'm replacing a BT modem, do I get it up as BT service or Plusnet (who is my ISP)?
Message 7 of 13
antinode
Guru
> I've tried setting the modem [...]
   Modem+router?
> [...] in 'modem only' mode [...]
   "tried" how, exactly?
> [...] but the network refuses to recognise this.
   Not a useful problem description.  It does not say what you did.  It
does not say what happened when you did it.  As usual, showing actual
actions (commands) with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> (who is my ISP)?
   "Plusnet"?  Whence came that?
> [...] What is the actual problem which you are trying to solve?
   Still a complete mystery.
Message 8 of 13
BigBobG57
   Modem+router? Yes then making it modem only
Advanced settings
When I connect the LAN cable to the modem, the router shows no internet connection while the modem has all LEDs green
interpretations.
> (who is my ISP)?
That's my ISP
I'm trying to connect DM200 to act as a router only onto a working network to replace a BT modem
Message 9 of 13
If all the LEDs on the DM200 are green it is connected to the Internet.
What is on the other end of this LAN connection?
What is this "working network"?
While the DM200 does have limited router features, it won't support much in the way of a network. It has no wifi and no spare LAN ports for network connections.
If you have a router, then you need to set that up too. Check the Quick Start guide.
There is support for the DM200, including the Quick Start guide and manual, somewhere at the end of this link:
>>> DM200 | Product | Support | NETGEAR <<<
Message 10 of 13
antinode
Guru
   Like most of this thread, that makes no sense to me.  What happened
to "I'm looking to purchase one of the above"?  Do you now _have_ a
DM200?
   A DM200 is useful as a DSL modem, and it includes a primitive router.
Because its built-in router is so limited, it makes little sense to try
to use a "DM200 to act as a router only".  Or did you mean "modem only"?
   You keep talking about "a BT modem", which apparently is a
modem+router.  It's veryhard to tell if you know what you're talking
about.
> That's my ISP
   So, Plusnet is your ISP.  They offer some kind of DSL service?  Is
your (still very poorly described) "BT 's UK FTTC (VDSL2/Infinity) May
be Huaweii" currently in use as your DSL modem?  And it works?
   And you now want to use your new DM200 as a modem-only (_not_ "a
router only") with your "my router Asus AC66"?  Or what?
   Is there some kind of voice telephone service tangled up in this
mess?
   We're now ten messages into this discussion, and no one seems to know
what equipment you have, or what you want to do with it.  Some of us may
lose interest very soon.
Message 11 of 13
BigBobG57
Modem only that should be
DM200?
I have one now
Yes I meant modem only
about.
Yes it's a BT modem that goes to a Linksys 8300 router
> That's my ISP
mess?
I don't think so
I just want to lose the BT Modem and if possible use the DM200 as the modem
Message 12 of 13
From what you have said before, you are nearly there.
If the LEDs on the DM200 are all green, then you havs successfully connected it to the Plusnet Internet.
Now comes the complicated bit.
If that is one of those Homehub boxes, then you cannot put it into modem only mode. So to get it to work painlessly with the Linksys EA8300 – I assume that this is the full model number – you may have had it working as a wireless access point. Or it may  have configured itself on setup to avoid conflicts with the Homehub.
To get the the Linksys to play nicely with the DM200 it makes sense to do two things:
  • put the DM200 into modem only mode
  • reset the Linksys 8300 so that it is working as a router
You said earlier that you "tried setting the modem in 'modem only' mode but the network refuses to recognise this".
Then you said "When I connect the LAN cable to the modem, the router shows no internet connection while the modem has all LEDs green".
We don't know what you were doing when that happened. One possible interpretation is that you didn't start the network in the correct order. Do that and things will not connect properly
  • Turn off and unplug modem.
  • Turn off router and computers.
  • Plug in and turn on modem. Wait 2 minutes for it to connect.
  • Turn on the router and wait 2 minutes for it to connect.
  • Turn on computers and rest of network.
Before you do that, reset the Linksys 8300 so that it forgets any settings that it picked up when connected to the Homehub.
You can then follow the setup instructions for your router.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 4121 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
