- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NETGEAR NIGHTHAWK D7800 Connection Dropouts Firmware Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have had ISP confirm it is not on their end and also recently upgraded wiring and phone ports throughout house ruling out a wiring issue on my end.
I have a nighthawk x4s D7800 V1.0.1.56
that for the last 12 months at least randomly drops connection at least 3 times a day and sometimes upto double digits. Super frustrating for me then have several (gaming) kids whining about it too.it has continuously got worse as time goes by.
When it drops about 50% of the time it will drop out and wifi channels dissappear and wired connections will even report "no connections available" as if the thing doesnt exist which also prevents me being able to login to the modem itself and will require a reboot to "fix"
About 20% it will only kick SOME devices for upto 10-15mins then allow them to connect again
the rest of the time it will drop and say no internet access or no ethernet plugged in ect and then reconnect after 5-15 mins
Ive read on an old post that it is a bug with firmware V1.0.1.47 and rolling back to firmware V1.0.1.44 fixes it.
Im currently running firmware V1.0.1.56
Does anyone know any other fixes for this issue yet?
From memory I think it was firmware V1.0.1.44 where a backdoor bug was found resulting in major security flaws however, tbh i do not actually know if that issue has been fixed or not with the updated firmware either. but still not keen on rollback unless absolutley neccessary.
Always swore by Netgear until now and will be purchasing a new Modem/Router as soon as I am able but seriously considering ASUS next due to the dissapointment with this model especially.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NETGEAR NIGHTHAWK D7800 Connection Dropouts Firmware Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having the same issue.
TRY 1:
Reset router by using hard reset button on modem
Result: Issue exist, constant wifi drop out
TRY 2:
Updated router firmware to V1.0.1.56
TRY 3:
Changes 2.4Ghz channel to 01 mode up to 800mbps and 5ghz channel - 36 mode - 1733mbps
TRY 4:
Disabled 2.4ghz and enable only 5ghz
Next I am going to try changing 5Ghz channel to 40
Wonder if we get any support from netgear
- Mark as New
- Bookmark
- Subscribe
- Permalink
has it been fixed for you?
i have the same issue, net drops out and i cant use ethernet or wifi to acsess http://192.168.1.1/ login
need to power cycle it
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
