- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Need help w/ consolidated communications ISP modem setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I sat on phone last night for about 4 hours back and forth between Netgear and my ISP tech support. The DSL light is solid white but for whatever reason, the wizard would always come up with "no internet connection detected". Would not pull an IPHONE address at all, always 0.0.0.0
Only thing I did not try was lvl 2 tech support with ISP because they charge $50 and I already paid $250 for this modem.
I can plug my other modem/router that ISP provided right back in and on comes the Internet. But it's a piece of crap and I want it gone
Any advice?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Need help w/ consolidated communications ISP modem setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have probably been through all this with support – you don't go into any of those details in your narrative – but have you tried a manual setup using the login details requiresd by your ISP?
See page 49 of the manual:
>>> D7000 | Product | Support | NETGEAR <<<
- Mark as New
- Bookmark
- Subscribe
- Permalink
Keep in mind this was the low level ISP tech support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The manual has a section for services that do not need login.
Sometimes all you need is your email address.
Which ISP is this? An ISP that charges for this sort of help is one to avoid. Maybe it has a user forum that is a hangout for fellow victims.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is no forum and unfortunately I can't switch ISP.....I live out in the woods and they are the only service available.
DHCP shouldn't require login information correct? I thought that was just for PPPoE
I have looked all over internet....there a few rare posts of victims but none that have a solution
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looking at the ISP's support pages I end up here:
This says:
2. Enter the High-Speed Internet User name and password found on your Internet Access Information Sheet.
So what are they doing telling you that you do not need this information?
Is there any way that you can get into the configuration of their modem and noting the settings?
This may also be a clue:
N600 ADSL2+ connection pair bonding - NETGEAR Communities
It may be back to using their modem with your box as a router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just looked at ur second link there and I'm pretty sure the bottom of the ISP modem says "bonded" on it.....so this might would cause my problems? If that's the case, then will it even work as a router if I bridget it?
Is there a netgear modem/router that would work for both?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Sero85 wrote:
I talked to a lvl 2 briefly at ISP and they said it should b plug and play....no login info needed. I also realized my dumbass was using the telephone cable provided with the netgear instead of the ADSL cable.....I finally got that to pull DNS info but still no IP/Internet connection.
Stuff happens. Anyone who claims never to have plugged the wrong cable into the wrong socket is a liar.
@Sero85 wrote:
I just looked at ur second link there and I'm pretty sure the bottom of the ISP modem says "bonded" on it.....so this might would cause my problems? If that's the case, then will it even work as a router if I bridge it?
I don't think Netgear does "bonded" modems. But I would not rule out bridge mode.
If it is a router, it probably does not care about the flavour of the Internet connection. It just wants a LAN connection from the modem to the Internet socket – check that one carefully – on the router/modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Guess this thing is going back to the store to exchange for a router only at half the price
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry about that. Here is the latest word that I can find on bonded modems:
Bonded DSL? - NETGEAR Communities
