- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear D7000 V1 set in AP mode, how to turn off WPS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, as title says I have a D7000 V1 setup as AP, works fine but I cannot see if there is a way to turn off WPS as the option is un high lighted in AP mode, is there another way to turn if off?
Also is there anyway to turn off main wifi in AP mode & just use guest wifi so i can isolate wifi from my home network with just internet access as i can not see any setting to do this?
thanks in advance
Gary
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D7000 V1 set in AP mode, how to turn off WPS
Just guessing Gary, but you might try first reverting the unit to normal router mode, then setting the options the way you want, and then switching to AP mode again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did try that originally, but soon as you set to AP mode from normal mode with it ticked to disable the tick box becomes unhighlighted and tick disappears from box.
Just feels to loose with wps on, may have to look at alternative device which does not do this in access mode.
cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] I have a D7000 V1 [...]
Firmware version?
> [...] soon as you set to AP mode from normal mode with it ticked to
Have you verified that the D7000[v1]-as-WAP actually does WPS, or are
you trusting the indication from the firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm running latest ver .78 & no I haven't tested it if its on or not just trusting the firmware as since we are in lockdown the AP is not actually at my place, i have a bridge running to my sons house & thats where the AP is for his internet access from me. maybe will have to wait to actually test it once lockdown is relaxed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
From your description of the WPS being "greyed out", that typically indicates that the function is disabled and not available. As Antinode suggests, you should try it to very that it is disabled as I suspect the item being greyed out would indicate.
