Reply
Netgear D7000 lower Sync rates
michty_me
Hi all,
Looking for advice on who to contact with regards to lower sync rates on the D7000 compared to other broadcom based modems including the Netgear D6400.
Here are a few stats from the D6400:
Max:    Upstream rate = 26040 Kbps, Downstream rate = 80441 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 74000 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Here are the same stats using the Netgear D7000:
Max: Upstream rate = 16715 Kbps, Downstream rate = 75697 Kbps
Bearer: 0, Upstream rate = 16730 Kbps, Downstream rate = 74000 Kbps
As you can see the Downstream attainable has lost 5Mb and the upstream has lost 10Mb. Is there somewhere that I can send this information to so it can be investigated? Other than that, Love this device so far.
Message 1 of 2
michty_me
Re: Netgear D7000 lower Sync rates
Sorry this should have been posted in the DSL section.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3632 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
