Reply
Netgear DGN2200
nathKent
Netgear DGN2200
I would nee some help in order to set up CNAME oon my router.
thanks
To force SafeSearch for your network, you’ll need to update your DNS configuration. Set the DNS entry for www.google.com (and any other Google ccTLD country subdomains your users may use) to be a CNAME for forcesafesearch.google.com. We will serve SafeSearch Search and Image Search results for requests that we receive on this VIP.
Message 1 of 8
Re: Netgear DGN2200
Try with @TheEther  or @StephenB.
Regards.
Message 2 of 8
nathKent
Re: Netgear DGN2200
Thanks Alexandra. I am not sure what you mean..
Message 3 of 8
Re: Netgear DGN2200
By doing what I did the wisemen @TheEther and @StephenB have been advised that you need some help!
Regards.
Message 4 of 8
TheEther
Guru
Re: Netgear DGN2200
Unfortunately, it's not possible to set up a CNAME with stock firmware.
Message 5 of 8
nathKent
Re: Netgear DGN2200
Thanks for your prompt reply. Which router would offer me this possibility? Thanks
Message 6 of 8
nathKent
Re: Netgear DGN2200
Good morning , wisemen @TheEther and @StephenB.
I was wodering if you know a router for which I can configure the CNAME.  OObjectif is to force all thee android phone/ to have a youtube restrcted mode.. thanks
Message 7 of 8
TheEther
Guru
Re: Netgear DGN2200
Any router that can run third-party firmware (DD-WRT, Tomato, OpenWRT, AsusWRT Merlin) will work.  Some business class routers will work.  Ubiquiti's Edgerouter, for example.
Message 8 of 8
Discussion stats
  • 7 replies
  • 3974 views
  • 0 kudos
  • 3 in conversation
Announcements
