- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk D7800 - Faulty firmware - .24
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Nighthawk D7800 - Faulty firmware - .24
Is there any update on when a post v1.0.1.24 patch will be made available, seeming this patch was for "[Bug Fix] Fixed security issues" the delay has us apparently vulnerable to the security issues?
I have tried to do a complete factory reset, apply the patch and then setup the router, but it doesn't see the port as active, telling me the cable is not plugged in.
The only fix for me was to roll back to v1.0.1.22
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
V1.0.1.28 has been released but I don’t see any mention of a fix to the above mentioned issue.
Has anyone installed v28 and if so was the issue resolved?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@hardjards wrote:
I an pretty sure that is a US firmware...
What makes you think that?
Netgear flags region specific firmware as such. This is not the case for this release:
D7800 | Product | Support | NETGEAR
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had the same problem for a while. The VDSL connection to the NBN refused to work after paying for the support I was able to receive a new router, problem solved. However, told not to upgrade to new firmware.
I have tested upgrading the firmware, keeping the previous version available, as soon as upgraded the internet stopped functionality. Rolled back to the previous version - worked - Problem diagnostic testing.
I am thinking about testing the latest version but need to make sure I have a working version first.
My current Firmware is V1.01.16 - everything is working fine but not happy that I cannot keep my product updated and protected from weak points
Hope this helps??
and as previous discussions seem to note the rolling back to a previously working version of the Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Case850 wrote:
I would say that if it is not mentioned in the release notes then it has not been fixed.
I wouldn't assume that. Netgear's release notes rarely say anything meaningful. Just bland statements about "Fixed security issues".
@pbosch12 is on the right track:
One thing you should not do when testing firmware is to save your settings and then restore them into the new firmware. That is a good way of bringing back issues that the firmware is supposed to fix.
It may be a pain, but if you have problems with new firmware installed, you should reset it all to factory settings and reconfigure the beast.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only assumption I made was that Netgear's communication is rubbish. I don't seem to be alone in that.
From other messages around here, the assumption that Netgear has not fixed issues beyond security with this new firmware seems to by wrong.
Solved: Re: D7800 Firmware Update to v1.0.1.24 - Page 2 - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have anything constructive to say about this issue? Or are you just here for the whine?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all , best thing is if Netgear wont listen on the forums , just take your Modem back to your Retailer with your POP , and then Netgear will need to RMA the modem. No use getting worked up , as I gather they dont monitor the forums. Heck I have been told they have no Australian Netgear IT staff anymore which would have picked the issue up quickly & had a new version out quicker. Dont flame the moderators , they are only trying to help , but probably have no say in Netgear fixing the issue.. Australia's consumer law was bought in for a purpose , just print off the forum notes & that can prove to seller , there is a problem... 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know who told you that, but I have seen messages here from people who have tried and failed to find local support. So this seems to be the case. Netgear now seems to run all its support "offshore".
That Netgear took so long to even acknowledge the problems with NBN wasn't encouraging. But the people behind NBN probably didn't help with their strange system.
How Australia Bungled Its $36 Billion High-Speed Internet Rollout - The New York Times
This strikes me as the best advice:
If you qualify, your modem is less than a year old, you could also start the on-line RMA process.
Whatever you do, avoid Netgear's invitation to pay for a support contract. They offer that automatically when you call the support lines.
This is not likely to solve the firmware issue and their support may well be less capable than the free support you can get here from the small band of unpaid volunteers and the even smaller band of Netgear staff.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately, I experienced the VDSL port issue described here after firmware update as well. I'm with TPG. After getting Netgear to replace my D7800 via RMA, the latest firmware update to V1.0.1.31 causes the VDSL port to constantly drop the connection. Have downgraded the firmware to V1.01.20 and connection to TPG has been stable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi , I am running version V1.0.1.31 on my Netgear D7800 with iinet ( same owner as Westnet / TPG) No issues at all with dropouts with VDSL , has been very stable since version released.. Doesnt help you , but maybe get support to check your line just in case? David
- Mark as New
- Bookmark
- Subscribe
- Permalink
The firmware is the old version and runs on VDSL
I have thought about the latest version but need to ensure complete backup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Via VDSL
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all , just a normal FTTN NBN connection owned by the Taxpayer 🙂 , my ISP is Westnet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Guys,
I've upgraded to the latest firmware v1.0.1.31 with no issues on NBN (iiNet), only thing I had to do was disable/enable the Dynamic DNS I was using to get it to identify the IP address for no-ip.
Otherwise its just running and behaving itself at this point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks everyone. I’m finally ready to update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all , upgraded to V1.0.1.34 too , working fine so far. NBN via FTTN - iinet. Though I have noticed my wireless dropping in & out with last version, so doing more testing, maybe my modem perhaps. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone know if V1.0.1.34 fixes the BT Openreach VDSL problem? I had to roll back to V1.0.1.22 to get a stable connection but would like to upgrade tp get the security patches - but will only do so if the BT VDSL problems have been resolvec.
- Mark as New
- Bookmark
- Subscribe
- Permalink
