- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear d7000 internet problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi
i m from morocco I bought a D7000 the internet line is synchronized but no connection
here my information about my adsl line
Status | Up |
Total Time | 7 hour 45 min 57 sec |
Modulation Type | ADSL_2plus |
Standard Used | G.992.5_Annex_A |
Standards Supported | G.992.5_Annex_A |
Link Encapsulation Used | G.992.3_Annex_K_ATM, |
Link Encapsulation Supported | |
Link Encapsulation Requested | |
Line Encoding | DMT |
Data Path | L1 |
Interleave Depth | |
ATUR Vendor | 5245544b |
ATUR Country | 181 |
ATUC Vendor | 4244434d |
ATUC Country | 181 |
Downstream | Upstream | |
Current Rate(Kbps) | 12495 | 1023 |
Max Rate(Kbps) | 20532 | 1343 |
Noise Margin(dB) | 14.9 | 12.4 |
Attenuation(dB) | 13 | 4 |
Output Power(dBm) | 1.5 | 4.5 |
where is the probleme pls help me
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
i got the solution:
You Must Change then DNS manually to DNS of ISP Morocco Telecom
For D7000 work with adsl of morocco telecom you must flow these steps:
1- Connect your Adsl line to your old modem when connected note the Primary DNs and the Secondary DNS.
2- connect your adsl line to D7000 and check Use these DNS Servers in the inernet setup page.
3- put the DNS of Morocco telecom
4- wait about 10 min to 20 min
Now ur Connected
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear d7000 internet problems
> [...] D7000 [...]
Firmware version? ISP?
> [...] here my information about my adsl line [...]
What do the LED indicators indicate?
> Status Up
Apparently your DSL connection is good. What about your PPP (PPPoA,
PPPoE) credentials? Do you have any special characters (<, >, |, ...)
in your PPP password? Multiple hardware models and firmware versions
have had firmware bugs which can corrupt a PPP password. See, for
example:
https://community.netgear.com/t5/x/x/m-p/1354547
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Firmware version?
D7000 Firmware Version 1.0.1.64
ISP?
maroc telecom (morocco)
my adsl work fine with wy old modem
all led indicators are white solid except internet led is amber
> Status Up
PPPoE) credentials?
we have PPPoE
credentials are correct
no special characters username:be.benana password:1234567
i dont know what is the problem?
if your modem not compatible with our ISP Maroc telecom (morocco)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Informations about my adsl Line
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
i got the solution:
Now ur Connected
