- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New firmware with built in Torrent Client
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rif.: New firmware with built in Torrent Client
Thanks for the continued work and updates. Just switched by fibre from BT to TalkTalk and the latest version is working well. Why must ISPs insist on sending me a free crappy router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi everyone,
I tried this one and the latest from without success.
I have VDSL2 service from Netia ISP.
When I was trying DSL is UP without any problems, but ppp is down, telling connecting repeatly.
My ISP says that I need to pass propper VPI,VCI and VLAN settings. I'm not sure how to do it, or it is a main problem.
When I used it as router connected to the external ISP`s modem ppp (pppoe) works ! otherwise as modem+router not.
Ppp in debug mode says nothing. I observed only sending packets PADI as I remember without any incoming packets.
Maybe there was something with unique_device settings.
Is it possible to pass My settings to the configuration:
VPI 8
VCI 35
VLAN 35
Regards
Kamil
I use DGND3700V1 Annex A
- Mark as New
- Bookmark
- Subscribe
- Permalink
A couple of things to look at. For my VDSL2 connection;
Log into the DGND3700
Advanced tab -> Setup -> ADSL Settings -> Transfer Mode = PTM
This same page also has your VPI, VCI and VLANID settings.
Be sure to check the box on the left of "Use VLANID"
Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
but the place to type VPI, VCI I have grayed out, except VLAN ID when I tap use it
Kamil
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try setting the transfer mode to ATM then enter your VPI and VCI. Normally VDSL2 uses PTM transfer mode which doesn't use VPI and VCI. I find it odd that your ISP gave you settings for those on a VDSL2 connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Found this for configuring a Fritzbox for Netia VDSL2. It shows VPI and VCI greyed out.
http://pomoc.fritzbox.pl/knowledgebase.php?article=13
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have problem, if restar router me all settings of transmision is deflaut, all media sharing off (deflaut).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
thanks it helps.
I've set all attribs in ADSL and then changed to VDSL.
VPI 8
VCI 35
VLAN 35
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Richud,
Is there any possibility to add ATM qos in your firmware as my isp told me to specify a PCR of 6144 or probably set it as hook like in pure L2 bridging config.
Thanks,
cedie
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New firmware with built in Torrent Client
Hi,
I sent a message on the wiki page but I'm not sure if this is maybe a more active forum. I have flashed the latest available firmware from the wiki page and I was evetually told it flashed successfully, although it took approximately 10 minutes. Unfornately now whenever I try to make a change to the router the web browser goes blank after a second or 2 and there is no change to the status lights regardless of how long I leave it but when I go back into the web admin, no changes have applied. I thought perhaps there had been an issue with the original flashing process so I have tried several times to reflash it but when the file is uploaded I get the status bar for a couple of seconds then the screen goes blank again with the sad face icon and a message saying no information has been sent (or something like that).
I really need to get this working with my Sky fibre as I am paying for a 40mbit service but only getting 22 - 25 on wifi (38 on ethernet but cables aren't practical due to the layout of the house). Sky have sent a second router out and it is doing the same. A search of Google has suggested this is a known limitation of the SR102 router due to the placement of the antenna and the shielding used.
Any help would be greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you flash the DGND3700 are you ethernet attached? What browser are you using? I've had trouble with router settings using Internet Explorer, but have found Chrome to be reliable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try a factory reset?
https://www.manualslib.com/manual/423135/Netgear-Dgnd3700.html?page=156
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't think it really has anything to do with Sky. When you're setting it up do you have the DGND3700 connected to the internet? I would try setting it up without being connected to the internet and also not having the PC connected to the internet. Other than that I'm out of ideas. I've not seen a problem like this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The PC you're using to attampt to configure the DGND3700 is not connected to the internet, just to the DGND3700?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have any Internet Security software installed that could be interfering with the new Genie interface? I guess you were running the old firmware with the original interface previously?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm going to go out on a limb here... Try completely uninstalling the AV and anti-malware, then uninstall Chrome and then install Chrome fresh. Then try and see if you still have a problem accessing the DGND3700.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like a bad flashing to me - I would reflash to stock then to the lastest firmware to resolve that issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
