- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk D7800 QOS set up questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am having a few hiccups with my QOS enabling on my NightHawk D7800 (Firmware V1.0.1.16)
I will list them as points as there are a few individual but related questions. If you can answer a particular point that would be great.
Thanks heaps!
1. Will automatic QOS allow Netflix Video streaming to happily co-exist with Online Gaming? This is my daily challenge! Or have many of you found it better to disable QOS all together?
2. When logging into the Advanced QOS section, the 'Enable QOS' is unchecked and the APPLY button is dark blue. When I click on the APPLY button it says 'Disabling Manual QoS and Dynamic QoS...' then it reverts to the same screen with the Enable QOS unchecked again???
Now, if I tick the Enable QoS box, I get a new selection with Dynamic QOS checked. and Manual QOS is unchecked.
However the APPLY Button at the top of the page, as well as Speedtest link and Update Optimization Data Base are greyed out and clicking does nothing.
Shouldnt the later 2 links work? before the APPLY button works?
3. When I select Manual QoS: Manual setup of QoS rules, the APPLY button and SpeedTest link turn purple and can be clicked.
Every time I do the speedtest via the routerlogin.net page i get the error "The Speedtest fails to detect the bandwidth, please check your Internet connection or try again later."
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk D7800 QOS set up questions
Hello GlO
Here is a article referring to your first question.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DarrenM,
Thanks, I have seen that link but that instruction doesnt match the options on the D7800 NightHawk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DarrenM,
The D7800 specific link http://kb.netgear.com/25615/How-do-I-manually-update-the-Dynamic-QoS-database-on-my-Nighthawk-router...
does not work as described.
